Alternate jackstand points
Old Nov 25, 2007 | 01:40 PM
wisk's Avatar
wisk
Default Alternate jackstand points
So I got this low profile jack from sears that isn't helping me at all. I gotta get the front of my car on some jack stands and I can't really get the whole thing high enough at one time in order to get both stands under there at once. Do you guys think it would be safe to put a jackstand in the knuckle portions of where the A-Arms bolt up to the k-member? Its got a sort of concaved area in there with both of the huge bolts that mount the a-arms up. I rested one side down on a jackstand there to see but I don't really want to put both sides down on them yet and find out the result.
Old Nov 25, 2007 | 01:42 PM
99gtstang's Avatar
99gtstang
Default RE: Alternate jackstand points
ORIGINAL: wisk
What about jacking up on the flange area and putting jackstands on the frame rail up front maybe on a piece of 2x4??? I have to do that. Getting jack and jack stand under at the same time was difficult. I have tried jacking under a few other spotsand i could see it bending!
Old Nov 25, 2007 | 01:45 PM
wisk's Avatar
wisk
See, last time I did all this I was able to get jackstands under the frame rails, but this little thing isn't so helpful. It started to roll back once and scared the **** out of me. I can't even get it high enough to get a stand under the skid plate. I'm really in a spot where I need the front up, with the springs relaxed, and where I can turn the wheel, but I don't want to be leaving the car on the jack the whole time and possibly sagging down
Old Nov 25, 2007 | 01:49 PM
99gtstang's Avatar
99gtstang
ORIGINAL: wisk
block back tires? My old truck was a pita to get up.... Used jack then put on jack stand then put 2- 2x4's on the jack againto get it higher.....
now it's just a pita to change oil ... i have to drive on blocks then the ramps because front is to low
Old Nov 25, 2007 | 01:50 PM
wisk's Avatar
wisk
Yeah got the back tires scotched and stuff. Hell I may just ago ahead and put the jack back under the skid plate and raise it up. Keep a good eye on it and everything should be alright. I got a couple 4x4 timbers I could probably put under the frame rails just in case the jack did fall some.
Old Nov 25, 2007 | 01:57 PM
wisk's Avatar
wisk
Ugh this sucks.
Old Nov 25, 2007 | 01:58 PM
99gtstang's Avatar
99gtstang
ORIGINAL: wisk
i tried skid plate and watched it bend
Old Nov 25, 2007 | 02:54 PM
Nitti00GT's Avatar
Nitti00GT
It's a bitch to jack up the our cars and put jackstands under them. The only think that I tried is the low profile jack and that was still a bitch.
Old Nov 25, 2007 | 05:45 PM
wisk's Avatar
wisk
Got it done.
Just jacked the front up, took the wheels off, put the jackstands under the a-arms, and then used the frame rails to lift each side to get the body up and strut out.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
flash_xx
Oct 16, 2015 07:23 AM
Sep 25, 2015 09:06 AM
