heads/cams help
I forgot to mention something. The guy said that the heads will need new valves - how much does this cost? The heads are also pitted, which he said will need a new port job, and chamber work - how much will this cost?
All in all, is this still a good deal?
Would the hp increase be different if i were to get patriot stage II heads/cams? I'm a little confused if the numbers would be the same for the PI heads/cams or the patriot stage II heads/cams, or is it all the same numbers? [&:]
ORIGINAL: gt96blue
