1/4 Mile ???
Old Jan 7, 2008 | 09:54 AM
Mustang_NTriangle's Avatar
Mustang_NTriangle
Default 1/4 Mile ???
As my signature states i have 4.10 gears and adding F/I w/ 10 PSI. I am looking to get new tires and wheels anyone hadNexen tires? Would 265/35/18s knock my 4.10 gears down to 3.73/3.90? I think I will be hitting 110 /115 mph in the 1/4 mile but currently top out around 108 in 4th gear and don't want to shift to 5th. I currently have 245/45/17s.
I never been to the track and wouldn't go often so DRs are out of the question.
Old Jan 7, 2008 | 10:13 AM
jsmarsh25's Avatar
jsmarsh25
Default RE: 1/4 Mile ???
I run DR's all the time. yes, they're a softer compound tire, and they do wear out a lot faster, but as long as you're not burning out at every red light and stop sign, they'll last you longer than you think.
Old Jan 7, 2008 | 10:16 AM
99GTvert's Avatar
99GTvert
is my username.
If DRs are out of the question, don't expect a great time.
With supercharged power and 4.10s, how else do you expect to hook in 1st, 2nd, and 3rd?
I don't know about if the 265/35 tire will drop your rear gear ratio that much (or if it will even go in that direction, hopefully someone else chimes in).
Old Jan 7, 2008 | 10:27 AM
Mustang_NTriangle
according to a gear calculator I will lose 2 mphs in 4th gear. I should have gotten 3.73s it goes to 121 in 4th. I never thought I was going to go F/I.
Old Jan 7, 2008 | 11:07 AM
02 GT's Avatar
02 GT
13.7 minutes
Old Jan 7, 2008 | 11:17 AM
02StangGuy's Avatar
02StangGuy
even if u throw some nitto drag radials on there it will help a lot. they arent the stickiest drag radial but they are a lot better then street tires and still have some decent tred life to them. +1, dont expect good times without drag radials when ur makin that kind of power.
Old Jan 7, 2008 | 12:22 PM
2000GT4.6's Avatar
2000GT4.6
guys, his main concern is running out of MPH in 4th gear and having to shift to 5th in the 1/4.. which is going to kill his times.
4.10s top out at 108? Holy crap, realise it was that bad.
I could be wrong but I dont think the tires are going to get you the 115 or so MPH your going to need.
Old Jan 7, 2008 | 12:42 PM
1fast 99gt's Avatar
1fast 99gt
get some 275/50/15 m/t et streets that will knock the 4.10 down.
Old Jan 7, 2008 | 12:57 PM
Mustang_NTriangle
Well in doing some research with tires and my 4.10 gearing. I believe my best bet other than DRs is to go w/ 275/40/18s all around. The 40 series tire will increase my 4th gear speed to 113/114 from 108. It will also allow me to rotate tires all around. It still won't ge me to where i would need to be but I might only go to the track once or twice.
Gene K
Oct 21, 2015 11:37 PM
heslekrants
Sep 23, 2015 04:02 PM
MonsterBilly
Sep 20, 2015 06:56 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
zachary1988
Sep 4, 2015 03:04 PM
