Bullitt Cluster FTW!
Foghorn Leghorn
Hot Damn!
I just purchased a brand new 2001 Bullitt instrument cluster off of Ebayfor my '02 GT. The font is very similar to my 67s and just looks absolutely ****. Can't wait until I get it and have time to install it.
If you have 10 minutes and some torx bits you will have no problem. i did mine in about 15 and i was really taking my time.
1. take off the headlight ****.. this was the trickiest part for me
2. there should be a few screws on the plastic trim around the gauges
3. same goes for inside on the cluster, once its out unhook the two connectors on back
4. unscrew the back of the circut board from both of the clusters and switch them, they should bolt right up. if you dont do this the PATS system will not let the car start.
5.reverse the process and you will have some sexy *** gauges to replace those gross green ones.
yeah welcome to the club!!! i got mine about 2 months ago... they are sooo sexy... yeah the trickyest part is that light switch... just pull that clip towards you as far as you can pull it and it should just pop off... everything else is a sinch!!
bullittjim, how come your car doesnt have the o.e. gauges??? j/w
ORIGINAL: tmas99
ORIGINAL: BullittJim
the guy who had it before me decided to put some white overlays (look like stock GT just white) and so now i have white faced gauges.
ORIGINAL: tmas99
andrew1969
16
Jan 8, 2016 02:48 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
JDWalton
Sep 24, 2015 08:47 PM
