Long Block vs Short Block
Old Feb 21, 2008 | 12:03 PM
jamesdl's Avatar
jamesdl
Default Long Block vs Short Block
What exactly is the difference beteween a long block and a short block. i know that the long blocks come fully assembled or what ever and that the short blocks are just the blocks but, what parts come on long blocks that dont come on short blocks?
And if i were to buy a mmr short block, what else would i need to buy and what parts can i re use form my stock block?
And same question as before for the long block.
Old Feb 21, 2008 | 12:05 PM
rainydayracing's Avatar
rainydayracing
Default RE: Long Block vs Short Block
Longblock comes with heads. If you don't blow the heads on your current block, you will be able to use them.
What is your plan? (new engine, then f/i?)
Old Feb 21, 2008 | 12:13 PM
96GT_PSL's Avatar
96GT_PSL
the short block consist of the block, crank, pistons, rods, and all the support parts. a long block is a short block plus heads, cams, and all the little gizmos that work with them like valves and such. if you buy the short block you will need to buy everything that is needed to turn it into an assembled engine. basically you'll need to buy the parts to make it a long block. then after its a long block get an intake manifold, wiring harness, and timing cover. i believe thats it. unless i forgot something.
personally, im getting just the short block. that way i can get my own heads and cams and not the ones supplied to me. it will end up being less expensive in the long run. if you buy the long block you may not be satisfied with the heads and cams that came with it so you may have just blown an extra $2k - $3k on something your not gonna use. but its all up to you.
EASTIDEE123
Sep 15, 2015 11:08 AM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
Sep 8, 2015 05:21 PM
Sep 8, 2015 11:50 AM
Sep 3, 2015 07:14 PM
