4.10 gears?!?
Old Mar 3, 2008 | 01:05 PM
bradstang's Avatar
bradstang
Default 4.10 gears?!?
i bought new motive performance gears, how will they go on my 03 mustang gt conv. auto. Will it hurt my rear axle? what will my top speed be if i also have a predetor tuner?
Old Mar 3, 2008 | 02:04 PM
01snake's Avatar
01snake
Default RE: 4.10 gears?!?
the top speed is a myth
a guy on svtperformance gps'd his 4.30's at 165mph and downhill at 170ish.
only way it will hurt your rear axle is if you launch with sticky tires seeing how the steeper gear makes more torque'y
Old Mar 3, 2008 | 02:39 PM
baino's Avatar
baino
^+1 on the hard launch
Old Mar 4, 2008 | 01:32 PM
bradstang's Avatar
bradstang
the only reason i ask is because i have 100,000 miles and i dont want it to give out. like is 4.10s to much for that?
Old Mar 4, 2008 | 01:45 PM
tws1098's Avatar
tws1098
like they just said it will be fine unless you are going to the track and launching hard, in typical street conditions you will spin and not put near the pressure on the axle.
Old Mar 4, 2008 | 01:48 PM
bradstang's Avatar
bradstang
ok thanks.
Old Mar 4, 2008 | 01:54 PM
99BlackPonyGT's Avatar
99BlackPonyGT
aka 'Negative Nancy'
dont listen to the second post about being able to hit 170 on 4.30s....yes it can be done, but you need a lot of power to back it up... svtperformance means it was most likely a cobra that did it, a near stock GT is not going to do 170 with 4.30 gears... not saying you are wrong 01snake, just saying that the way you typed it is a little deceiving
Old Mar 4, 2008 | 02:00 PM
sstang's Avatar
sstang
That was probably a powerful cobrawith more/longer gears than what a GT automatic has. The top speed will be lowered a little bit on a basically stock GT, but you shouldn't tach out before a 1/4 mile, which in my book is all that matters.
And don't worry about your axles if you do notever go to thedrag strip. And if you do go, you willonly need to worry if you are usingM/T et streets or race slicks. You need a pretty sticky tire to break them, as a street tire will spin before the axle breaks.
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
