idle problem
Old Mar 9, 2008 | 01:17 PM
blee69mustang's Avatar
blee69mustang
Default idle problem
What would be the problem when putting on the brakes or turing the wheel to cause the idle to get real rough and sometimes kill the eninge. is this just a bad power sterring pump or is a sensor out of wack. its my 98gt, if that makes a difrence
Old Mar 9, 2008 | 06:30 PM
blee69mustang
Default RE: idle problem
bump
Old Mar 9, 2008 | 09:05 PM
mestit3's Avatar
mestit3
auto or manual? and does it do it besides just when youre turning and stoping?
Old Mar 9, 2008 | 10:28 PM
blee69mustang
ORIGINAL: mestit3
manual.
nope it only does it when im turning or braking. those two units are one on the mustang, because i know if you loose your brakes you loose your power steering too or vis-versa. is it a bad power steering pump, thats what im maybe thinking but im not sure.
Old Mar 9, 2008 | 10:37 PM
Ecstasy's Avatar
Ecstasy
sounds like the pump maybe going out, as far as the brakes, not sure.
Old Mar 9, 2008 | 10:49 PM
GhostRider02GT's Avatar
GhostRider02GT
the brakes run off hydroboost(which feeds off the power steering pump)on 96+stangs
Could be something like the pump or maybe the IAC isnt responding as quickly to increase air for the increased load, mine does it sometimes, never dies though and never is that noticble of a rough idle
also could be the hydroboost itself going out(hope not, SOB is expensive)
Old Mar 10, 2008 | 08:45 PM
blee69mustang
ORIGINAL: GhostRider02GT
alright thanks it could be the IAC, just because its been 100k miles it might be all worn out, and its a cheap part to replace, if not ill have to try the power sterring pumps, thanks a lot for the help.
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
