installing cams
Old Mar 15, 2008 | 07:40 AM
00blackstang's Avatar
00blackstang
Default installing cams
Can i install the cams on my car myself?... i am pretty good at mechanical stuff.. Ive done all the suspension and exhaust and everything on my car.. Is it really that hard.. Also , do i need anything else beside the cams and the springs?
Old Mar 15, 2008 | 07:51 AM
StangEatsRice's Avatar
StangEatsRice
Default RE: installing cams
I have not done cam spring so I am not going to try and tell you how hard or not they are, but the cams are very doable. You can find on other sites stickies on doing cams without undoing the front cover, tried it, messed up, do it right the first time.Crank pulley, valve covers,remove the front cover, then undo power steering pump hang it out of way, next is tensioners, cam caps, swap cams and button it all up. This is not all of it just the basic of what needs to happen. I jumped into it by myself and was able to get it done in 8hours with a electric impact gun. I wouldn't pay a guy 800 for a cam install save the money and do it yourself.
Old Mar 15, 2008 | 09:13 AM
jrherald420's Avatar
jrherald420
it can be done but make sure you know your stuff BEFORE you attempt it.thers a tool that helps you get the timing locked in if you dont really know how to do it. ill try to find it. read up and good luck
mtgldr
Feb 3, 2024 09:00 PM
Luke9222
Oct 22, 2015 11:55 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
Luke9222
Sep 4, 2015 06:46 AM
