Rear end girdles (1%ers in here)
#21
RE: Rear end girdles (1%ers in here)
ORIGINAL: blackonblacksls
this is the first i have seen people make such a big deal out of the rear end girdles... i dont really see how they would make a difference, it seems like a wierd place to flex enough to hurt anything..
Then everyone else can look at your rusty diff cover as you blow by them.
But seriously I was just pointing out how strong the Ford 8.8 rear really is!
[IMG]local://upfiles/95778/7EFCA865CDA44E17B380D4C423686BB6.jpg[/IMG]
#22
ORIGINAL: 9 Sec 93 LX
All I'm saying is spend your money where it's needed.
#23
#24
ORIGINAL: 2000GT4.6
case flex and internal gear movement is probably the number 2 or number 3 reason for failure, after axle tube movement and acutally shearing a gear (more likely on a stock 28 spline setup).
My list of rearend failures.In Order of failure
1.weak factory posi unit
2. wimpy factory axles
3. main cap breakage, what everybody doesn't understand is if the cap cracks (THE GIRDLE DOESN'T WORK!)
I never sheared any gears? 28 spline?
Thats all I gotta say.
I'll be quiet now.
#25
Who told you that? (The guy who sold you the girdle.)
I'll be quiet now.
ORIGINAL: 2000GT4.6
I'll be quiet now.
Its an open bowl, with one side basically having nothing but a thin metal cover (that does nothinig). Is it that hard to see it flexing?
When I did my install I also did the main studs, and the main studs now come into contact with the girdle supports (would without em too). So, you basically have a thread that goes down into a hole, then has a nut holding the main caps, and then the stud is more or less attached and supported from movement by the outer girdle.
Your acting as if this is a 1000,000 dollar mod or something... its a couple hundred bucks, can't do anything negitive, undoubtably makes everything stronger, and it makes the rear fluid a LOT easier to change if you so wish, plus it looks good. Exactly what is your case against it? Surely someone with a 9 second foxbody doens't have a care in the world about spending less than 300 dollars.....
Edit: the main reason that anything will break in the rear is not that it acutally snaps, its that it MOVES and this puts it in a bind and breaks it. The girdle may not eliminate all of this movement but it does help reduce it, and anything you can do to help reduce movement has to be pretty good.
#26
heres a link on the corral, to a rear cap install. They also talk about the main cap support, and you can't help but admit that the stock cover > aftermarket just by looking at it...
http://www.corral.net/index.php?opti...&Itemid=26
edit: corrall doesn't sell anything, and they don't exactly need to pander to anyone to get ads...
#27
ORIGINAL: 2000GT4.6
The aftermarket girdles support the main caps if you acutally do the install correctly. Thats 1/2 the entire point of the girdle, the other point being to eliminate case flex.
I'll be quiet now.
ORIGINAL: 2000GT4.6
I'll be quiet now.
Just trying to save you a little $$$ thats all bro.
You're right about me spending the money (chump change).ie I'd have one if I needed one.
Over 100 9 second passes w/o one(girdle) Thats all!
How FAST did you say you were going anyhow?
#28
i never will understand why people would even thinkg about takingadvice from people who read **** over the internet, and not from people who are out there getting it done... ring and pinions are not going to get tore up in a 400rwhp gt.... How often do you see a ring and pinion come out of a rear end looking real bad? caseflex is nothing to worry about.. take care of your axle tubes, actual dif, and, axles and you dont have anything to worry about.
#29
Finally someone who understands what I'm talking about.
#30
ORIGINAL: 2000GT4.6
Whats in your garage a PRO MOD?
Dragonus18
09-09-2015 01:21 AM
