msd windows switch problem
Old May 5, 2008 | 08:58 PM
01snake's Avatar
01snake
Default msd windows switch problem
when under easy acceleration it is fine....
BUT when i go WOT it will just go to zero, and if i dont touch the gas for a while will go to zero.
also noticed when idiling it will bounce SOMETIMES from 700-200-0-100 sumthin like that
any ideas?[:@]
Old May 5, 2008 | 10:06 PM
1fast 99gt's Avatar
1fast 99gt
Default RE: msd windows switch problem
yeah get a bloweri dont have a box control my power
Old May 5, 2008 | 11:15 PM
01snake's Avatar
01snake
when i am at your side on the 50 shot dont cry[8D]
Old May 5, 2008 | 11:21 PM
01yellowgt's Avatar
01yellowgt
where did you hook up the tack wire.
I think im changing to a nx window switch actually.
Old May 5, 2008 | 11:28 PM
01snake's Avatar
01snake
to the green wire with a white stripe on the pcm
it has tobe the right wire or it wouldent read my rpms at all
Old May 6, 2008 | 11:59 AM
blackonblacksls's Avatar
blackonblacksls
i actually just had some similar problems on a msd window switch.... everytime you would hit wot switch it would turn off... it ended up being the switch i had it hooked up to.. either it was too small or it was just a bad switch. Try throwing a power wire directly to the power of the window switch and see if it still happens.
Scottyboy187
SVT Forums
Nov 20, 2015 02:57 PM
Scottyboy187
Nov 5, 2015 04:18 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
HorsePower99
Aug 26, 2015 11:29 PM
HorsePower99
Aug 26, 2015 08:32 PM
