lifting rear
Old May 8, 2008 | 02:00 PM
03StangerGT's Avatar
03StangerGT
Default lifting rear
I tired using the pich point in the rear but it just bent. I can't get the the subframe since my car is too low. Where do I put the jack to lift my rear safely??
Old May 8, 2008 | 02:05 PM
GodAmGT00's Avatar
GodAmGT00
Default RE: lifting rear
Use your tire jack to get the car high enough up to get a floor jack underneath, and I believe there is a flat spot right in front of the control arm mounting point (torque box) that is solid enough to lift with..
That's what I did with my cars..
JT
Old May 8, 2008 | 02:10 PM
1sloblckgt's Avatar
1sloblckgt
I just jack mine up from the diff...
Old May 8, 2008 | 02:11 PM
03StangerGT
okay thanks, ill try it
Old May 8, 2008 | 02:39 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
ORIGINAL: 1sloblckgt
[/align][/align]The factory shop manual says don't, in great bold letters with a big yellow caution sign. [/align][/align]Nonetheless,I've done it buthave tried notmake a habit of it...[/align]
Old May 8, 2008 | 02:50 PM
03StangerGT
well I don't know where my tire jack is so that odut of the question now. I'm not sure where the torque box mounting point is tho...
Old May 8, 2008 | 04:55 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Jacking points...
Old May 8, 2008 | 06:18 PM
03StangerGT
thank you kindly!
mtgldr
Feb 3, 2024 09:00 PM
KingRando
Oct 1, 2015 11:16 AM
musnicki
Sep 23, 2015 07:11 AM
Sep 16, 2015 07:53 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
