key copies
Old Jun 6, 2008 | 07:11 PM
socool9004's Avatar
socool9004
Default key copies
so i have one key and one fob for my car, anyone know where i can get a good blank transponder key? and what i can expect to pay from the dealer to have them do the deed with it?
Old Jun 6, 2008 | 07:44 PM
richsw's Avatar
richsw
Default RE: key copies
I had one made at my local Ford dealer a few months ago.
60 bucks.
I was worth the peace of mind. Having only one key is scary.
Old Jun 6, 2008 | 07:48 PM
248spider's Avatar
248spider
yeah it is pricey for a dup key but any hardware will copy it so you can at least get into your ride but not start[:@]
Old Jun 6, 2008 | 07:55 PM
richsw's Avatar
richsw
If you loose your ONE key...it will cost you a lot more for the tow job to the dealer
and a lot more for them to fix it. Not to mention the aggravation.
Old Jun 7, 2008 | 01:09 AM
OUTLAW1969's Avatar
OUTLAW1969
I hate to even mention them, but Walmart has these keys available (with programming).
Old Jun 7, 2008 | 01:43 AM
Lombardo05's Avatar
Lombardo05
i went to a local shop and the took the chip out and soldir (sp) it in the ignition i think idk but now i can just use regualr keys. i did this b/c i had only one key and a second would have costed me like 80 bucks... hs worked fine for the last year. oh and the key has a false door on the top thats how the chip comes out.
Old Jun 7, 2008 | 02:09 AM
socool9004's Avatar
socool9004
ya...but now you have no PAT...or anti theft, going back to outlaw.....walmart really has these keys with programming?
Old Jun 7, 2008 | 06:52 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
Any local locksmith shop will have the programmerFluke makes a kit with "personality modules" that works on nearly every car with similar key coding.$40 to $50 is the usual price for the key and programming same.[/align][/align]Also, you don't need to remove the "chip" and solder anythingjust tape a key tp the lock assembly under the plastic sterring column cover. [/align][/align]PersonallyI like PATS, I never lock my car and leave the windows down unless it raining.There's nothing of any value in it, and the PATS (you'd have toreplace the instrument cluster and PCM with a programmed matched pair to defeat it) is very effective at ensuring no one is going to steal it...[/align][/align]
Old Jun 7, 2008 | 02:13 PM
Lombardo05's Avatar
Lombardo05
i have a aftermarket vipe alarm works good for me idk. never had any problems but im not real knowledgable on this subject just thought id share what i did
lincolnshibuya
Dec 8, 2015 04:37 PM
logan409
Sep 26, 2015 07:43 PM
jessicarabbit
Sep 25, 2015 12:41 PM
Sep 8, 2015 11:50 AM
