Shift kit and Tranny cooler
So our search sucks....
So i want to order a shift kit and tranny cooler.This is my daily driver so nothing rediculous but i want it to shift pretty nasty.... Does that even make since lol [&:]
So which one/what kind?
Where do you get it?
I want to hear your experience with the product.
Thanks
Thanks
Trans-Go all the way... It seems to be the benchmark standard for the AOD-E..
As for Trans-coolers, there is a variety.. To be honest with you, the generic one you buy at Autozone is just as good as the $150 piece they sell in Summit.. The key is finding the Efficiency range. When I had mine, I knew that I would be beating the sh-t out of it daily, so I chose the one made for vehicles towing in excess of 3500lbs.. It dropped the temps by about 25% average, when used in conjunction with the shift kit..
JT
JT
Go TCI! Read the article on the 99 test stang. They used the Trans Scat Kit and the Converter and took off 4ths off their stang's 1/4 mile time. If it was at sea level, it would have run 12's.
http://www.tciauto.com/Products/Ford/ford_aod.asp
ORIGINAL: johnr2001gt
Do the j mod by far the best for your auto.
http://www.tccoa.com/articles/tranny...on/index.shtml
ORIGINAL: Adam03GT
Ya i always hear transgo is great.
So are you saying you got the cooler from Autozone and it works great?
Yep.. The only issue you may have with one of the generic coolers, is that you may need to fab up some sort of mounting bracket for it.. The good news is, you don't need to run additional lines, since there is a tiny cooler integrated into the radiator... I believe they are -AN fittings, and I believe they provide adapters to go from an -AN or flare style fitting, to a soft rubber line.
I bought some small pieces of angle iron and made up a little bracket that would fit in the front fascia, that used self-tapping screws. I never had to worry about it fall out, and like I mentioned, it significantly decreased tranny temps..
JT
ccdguy
Sep 19, 2015 05:20 PM
