Maximum Motorsports Rear Suspension??
RE: Maximum Motorsports Rear Suspension??
I have CC plates and LCA's from Maximum Motorsports and they helped my 04 GT's handling a lot.
MM makes very well built products but I've never used the setup you are looking at.
These links can help.
http://forums.corner-carvers.com/
http://www.miracerros.com/mustang/index.htm
Read some of the articles here also.
http://www.protoworks.com/cgi-bin/C-C_Wiki.pl
ORIGINAL: ddmsgtr1
If you had to do it again, would you do it the same?? How well does it perform??
Long story short? Best thing I could have done on the car!
BTW be careful what you post at Corner Carvers. The boys there aren't very tolerant of suspension newbies!
John
ORIGINAL: Zoie_daGT
Wow, I like that review. I like hearing from people who actually have the mod in question.
[align=left][/align]
John
Street & Strip Box, 1999-04 GT HT
[clickforlargerimage]');
$1,576.49
Part #: DB-7
Manufacturer: Maximum Motorsports
Product Photo Note:
Due to differences between production years and models, the actual product may differ slightly from photo.
Add:
Designed with straight line speed in mind, the Street & Strip Box is customized with soft springs and shocks which help transfer weight due to CG shift as the car squats. The soft springs and shocks also store the energy of the initial launch to keep the rear tires from breaking loose. Adjustable Tokico D-Spec struts & shocks, Caster/Camber plates and our ride height-adjustable Drag Race Rear Control Arms give you the stability and durability you need, with the flexibility to remain streetable.
The Street & Strip Box includes the following parts:
[ul][*]MM Caster/Camber Plates*[*]MM Full Length Subframe Connectors[*]MM Drag Race Adjustable Rear Lower Control Arms[*]Tokico D-Spec Struts[*]Tokico D-Spec Shocks[*]H&R Sport Springs[*]Ford HD Rear Upper Control Arms [/ul]* Available with triple-plated chrome finish, $50 extra. Note if you want chrome in the special order instructions during checkout.
musnicki
09-23-2015 07:11 AM
09-16-2015 07:53 PM
09-08-2015 11:50 AM
