wheel stud replacement help
Old Jun 22, 2008 | 11:01 PM
PaintballFreak's Avatar
PaintballFreak
Default wheel stud replacement help
So I broke off a wheel stud from each of my rear wheels at the end of my suspension install this weekend. Everything else went smoothly though. Any tricks to replacing them or is it remove caliper/rotor, knock out the old one and insert the new one? Then just use a lug nut to draw it into position right? I dont think I've actually ever taken the rotor off the rear? Is it different than the front? And do I need to do anything more with the e-brake than take the end of the line out of it's bracket thing?
Thanks for the help guys.
JD
Old Jun 22, 2008 | 11:23 PM
MustangMan00's Avatar
MustangMan00
Default RE: wheel stud replacement help
just leave the e bake off....take off the caliper, the bracket...rotor..hammer out the stud..and pull in the new one with a lug...ive done em liek 3 tiems on mine[:@]
Old Jun 22, 2008 | 11:37 PM
PaintballFreak
2 bolts for the caliper and 2 more for the bracket right? I've never taken it off in the rear.
Old Jun 22, 2008 | 11:41 PM
ZW99GT's Avatar
ZW99GT
Yup. Same as the front as far as the caliper removal, IIRC. I had to replace 2 studs the other night at the track. From the time I stripped them out, hitched a ride to Advance and got them in was less than an hour.
Old Jun 23, 2008 | 09:00 AM
califas_1987's Avatar
califas_1987
Here's a link to a helpful thread https://mustangforums.com/m_3698976/tm.htm
there's some pictures at the bottom that show what's behind the rotor once you get it off. You'll need to lube the stud up a little bit, but it'll pull through easy enough past the abs ring and through the hub. buy the stud and an open ended nut with a flat edge to pull the stud through.
Old Jun 23, 2008 | 06:32 PM
PaintballFreak
worked perfect! Thanks guys!
Urambo Tauro
Dec 17, 2016 03:30 PM
kdryan
Aug 29, 2015 09:57 PM
dba Brakes
Aug 23, 2015 06:08 PM
jjwinel78
Aug 17, 2015 03:34 PM
FD725
Aug 11, 2015 03:43 AM
