MAF HP?
Old Jul 14, 2008 | 12:19 AM
steve0914's Avatar
steve0914
Default MAF HP?
will i see any performance gains by adding a larger MAF? a buddy said more air passes through so therefor the engine puts in more fuel...i googled this, but it seems like some people say yes and some say no...
Old Jul 14, 2008 | 12:27 AM
H0SS302's Avatar
H0SS302
Default RE: MAF HP?
NO
the only reason to upgrade your maf is if u have a blower
Old Jul 14, 2008 | 12:29 AM
defconfire's Avatar
defconfire
Default RE: MAF HP?
Most people replace the the MAF because the stock one becomes a bottle neck with FI
Old Jul 14, 2008 | 12:34 AM
steve0914's Avatar
steve0914
Default RE: MAF HP?
thats what i thought... i assumed that the MAF had to be bigger than my t/b plenum so....
Old Jul 14, 2008 | 05:22 AM
oxfordgt's Avatar
oxfordgt
Default RE: MAF HP?
A MAF is a supporting mod just like injectors and fuel pumps. You will gain no power from upgrading them unless you have reached their current limit. Upgrading to a larger MAF is not the best idea. 90mm + is to big for any FI 2v car. The stock MAF is big enough to support over 800hp as long as you upgrade the electronics. When you use to big of a maf it will give a false reading.
Old Jul 14, 2008 | 05:11 PM
tbirdscwd's Avatar
tbirdscwd
Default RE: MAF HP?
+1 your not gonna gain any power by replacing the MAF unless the current one your running is already pegged. For a blow-thru setup you want the diameter as close to the same size as the rest of the piping to minimize turbulence which causes false readings. Although, you will definitely benefit from a larger diameter MAF on a draw thru blower setup.
OP, the amount of air your engine ingests doesn't change depending on what size maf you have. The MAF simply reads how much air is coming in. It takes a voltage reading which is sent to the PCM then is traslated into a specific amount of air based on the values loaded in your MAF transfer table (written in your tune).
Jb145700
Aug 21, 2022 06:37 AM
jwog666
Dec 27, 2021 08:09 PM
piotrek53
Oct 13, 2015 06:54 PM
mltdwn12
Sep 23, 2015 08:54 AM
stangin1996gt
Sep 21, 2015 11:01 AM
