x pipe problems
Old Jul 27, 2008 | 10:23 AM
mustangchris09's Avatar
mustangchris09
Default x pipe problems
Still i have a freaking leak. I dont know what to do, ive taken it in and the leak was fixed and then it came back again, ive bought four gaskets.1 from ford and the 3 from fel pro. I dont know why its still leaking. It seems to me that its the bolt right next to the starter that just wont stay tight, or get tight. New Bolt maybe?? i dont know, i want to get a t/b plenum combo, but im not spendin another dime until that leak is gone, its so anoying. Any help or ideas please???
Old Jul 27, 2008 | 10:36 AM
baino's Avatar
baino
Default RE: x pipe problems
Why not weld it in
Old Jul 27, 2008 | 10:52 AM
kast1376's Avatar
kast1376
ORIGINAL: mustangchris09
What did the shop say they did to the car each time they "fixed" the leak? Did they claim it was the gasket each time? I would climb under there and check the bolts, if they are getting loose, replace them.
mustangchris09
I was thinking that, but what if the x pipe has to come out for lets say transmission problems. It cant be good to constantly cut and weld cut weld all the time can it
Old Jul 27, 2008 | 12:33 PM
black35th's Avatar
black35th
Have you tried to Loctite the bolt?
Old Jul 28, 2008 | 06:16 PM
Lefty's Avatar
Lefty
how many miles have you put on since the install? I know after I did mine with a new felpro gasket it still sounded like it was leaking, I drove it to heat it up and then put it back on the lift and tightened the bolts one more time. It still sounded like a leak but I just ignored it.I have put probably 2000 miles on since the install and it sounds great. I don't know if maybe the heat from the exhaust sealed up any small leaks that were there? Can't be sure, but put some miles on it drive it for awhile see if that helps?
Jb145700
Aug 21, 2022 06:37 AM
2007CalSpec
Dec 13, 2020 11:42 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
Webster454
Sep 7, 2015 04:59 AM
