180 t-stat
haha i knewwwww i shoulda googled it!! what is it?
and im really just gonna be a extra set of hands to put the engine together. The brains is the guy who owns the shop and is helping (well really doing) me put it together
If you are staying NA then leave it stock. You only need to drop down the Tstat when making big power but at the same time you have to upgrade the entire cooling system. The 192* tstat is just fine.
ORIGINAL: oxfordgt
(no that wasn't sarcasm that was serious, im not being an *******)
i run a jet 180 t-stat. i can tell you it most definately helps the car run a bit cooler than it was before the 180 t-stat....which helps...especially in okc where its been getting close to 110 degrees outside everyday.
I'm pretty sure I'm the one who told you to get one. They are like 10 bucks tops. It is just a thermostat. and the 180 means it starts reading temps at 180 degrees. It is located on your intake manifold on the driver side. It never hurts to buy a new one.
inyadreems
Aug 21, 2015 09:10 AM
