Short Throw Problems
Old Sep 24, 2008 | 07:30 PM
96GTnate's Avatar
96GTnate
Default Short Throw Problems
Ok so i bought this car with the short throw already in it. Now in my '03 GT the stock shifter was SOOO much easier to shift.
So i dunno if this short throw needs to be adjusted or something but i assumed going from stock to that it would be smoother/easier. I mean i have yet to successfully get it into second at high RPM. And im definitely not new at the racing scene.
It kinda feels like it catches up on something just moving it from left to right in neutral. And getting it into gear is a little more difficult than i would expect it to be.
So if you guys have any suggestions that would be great. Thanx
Old Sep 24, 2008 | 07:52 PM
lizzyfan's Avatar
lizzyfan
Underboss
Sounds like a tranny issue not a shifter issue
Old Sep 24, 2008 | 08:04 PM
96GTnate's Avatar
96GTnate
No the tranny seems fine. no grindage or slipage. ill go ahead and see where all the stop screws are backed up to and what not, and see what i can fin i guess
Old Sep 24, 2008 | 09:15 PM
blackstallion666's Avatar
blackstallion666
what kind of shifter is it?
Old Sep 24, 2008 | 09:39 PM
02 Ninja's Avatar
02 Ninja
+1, I doubt it's the shifter and if it is, it's a crappy one...........probably MGW......................................lol J/K. Just knew that would raise a few feathers.
Old Sep 24, 2008 | 10:03 PM
562cobra's Avatar
562cobra
or probably a tri ax.........................lol J/K too. you suckahs shall never know what i have Muahahahahahahaha
Old Sep 24, 2008 | 10:06 PM
blackstallion666
your clutch cable may just be a little stretched cuasing your issues now thinking about it.
Old Sep 24, 2008 | 10:57 PM
03mustgt's Avatar
03mustgt
Check the shift stops, if its not them then I would be looking at the tranny. You could just pick up a new shifter to see if the problem goes away.
Old Sep 25, 2008 | 12:19 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
A short-throw shifter (any STS that really decreases the throw) increases the amount effort required to move the lever between gears--this is just fundamental mechanical principle. Since to amount of force and motion required to actually change gears (in the tranny) remain constant the only way to shorten the "throw" is to shorten the "top" part of the lever (above the fulcrum) and/or raise the fulcrum and lengthen the "bottom" part of the lever.
Most aftermarket STS' do both, thus decrease the leverage as compared to the OEM shifter. Given a fixed force and required motion on one end of a lever, decreasing the leverage will always decrease motion and increase required force on the other end of the lever--gotta happen!
In short (no pun intended) aftermarket short throw shifters are not in any way about making shifting smoother or easier, just making it faster...
Roush05
Sep 10, 2015 12:23 PM
vintageaion
Sep 8, 2015 10:45 AM
Webster454
Sep 7, 2015 04:59 AM
Sep 3, 2015 07:14 PM
cbird1177711
Sep 2, 2015 08:51 PM
