Fuel Pump Issues
Old Oct 27, 2008 | 06:44 PM
A_LOU_THANG's Avatar
A_LOU_THANG
Default Fuel Pump Issues
I have a 04 gt, with 55,000 miles. I was told today by my mechanic that my fuel pump is bad and needs to be replaced. I have not had any problems with the car starting until the other day. The thing just wouldn't start. I assumed it was the fuel pump because i could not hear it turn on. The car was towed to the shop, and then it started as soon as the tow truck left. Go figure. It started the next 5 times, but eventually wouldn't start again. Anyone experience something like this before? Seems like a pump should last longer that 55,000 miles. I believe the diagnostic check told them it was the fuel pump. I trust my mechanic as i have taken cars to him for years. Is it possible I just got a crappy factory pump?
Old Oct 27, 2008 | 06:55 PM
Obsequious1's Avatar
Obsequious1
You could check your schrader valve to see if you have fuel pressure. It could also be a fuel pump relay going bad if you don't always have fuel pressure. I don't trust mechanics because I work around so many and know their game.
Oh yea, I was once a mechanic.
Old Oct 27, 2008 | 08:00 PM
blackstallion666's Avatar
blackstallion666
honestly i had a 03 gt in work a couple weeks ago with a bad fuel pump and it only had 52,000 miles on it.
Old Oct 27, 2008 | 08:05 PM
forcefeed's Avatar
forcefeed
it sounds like you don't trust you technician, most reputable shops will not charge you for the repair if they mis-diagnosis the problem.
and yes the fuel pumps do fail, when was the last time the fuel filter was changed?
1TUFF302
Nov 5, 2015 04:02 PM
TfcCDR
Sep 14, 2015 12:08 PM
zanemoseley
Sep 6, 2015 12:58 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
