A different DR question.....
Old Jan 2, 2009 | 05:22 PM
POISND U's Avatar
POISND U
Default A different DR question.....
During AGGRESSIVE driving, do the softer sidewalls make the rear noticably looser? I'm not asking those who only take corners on city streets, I wanna know from AutoXers and those who play on mountain roads and enjoy hanging the tail out.
With the H&Rs and 4.10s, traction is a problem with my 295/35 Toyos and I'm trying to decide between DRs or a HPDE type tire like RT615s and NT01s. I want to hook in 1st on the street and at the track and still maintain a planted rear around turns.
Old Jan 2, 2009 | 05:33 PM
01GT4.6's Avatar
01GT4.6
I obviously can't speak from experience but I'd think that it will affect it some, but not much since it's a low profile tire.
Old Jan 2, 2009 | 06:09 PM
Timspony's Avatar
Timspony
SVT Section Moderator
...I've never had a problem!
Old Jan 2, 2009 | 06:19 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
If you wanna turn, then buy the NT01s, if you wanna hook in a straight line, buy MTs. You really cant compromise the 2. The ET street radials have a pretty stiff sidewall for a drag tire, and handle decent. But I wouldnt expect miracles around the mountain roads. One little bit of dust and your spinning in circles.
Old Jan 2, 2009 | 07:04 PM
Novanutcase's Avatar
Novanutcase
What else do you have other than springs out back? What's probably happening is your rear axle is moving around making the car feel "twitchy". Do you still have the OG IRS?
John
Old Jan 2, 2009 | 07:05 PM
H0SS302's Avatar
H0SS302
John
na he has SRA
Old Jan 2, 2009 | 07:49 PM
Novanutcase
Originally Posted by H0SS302
na he has SRA
Then he should change out his rear lower arms for ones with stiffer bushings. I'd also replace the upper arm bushings with fresh stock bushings. DO NOT replace uppers with poly bushings. You'll damage the torque boxes if you do this. Pair it with a PHB and you'll be canyon carving with the best of them!
Adjustable rear sway wouldn't hurt either!
John
Old Jan 2, 2009 | 11:21 PM
blackonblacksls's Avatar
blackonblacksls
mt drags feel similar to a street tire during turns and such...
Old Jan 3, 2009 | 06:51 AM
jmac72187's Avatar
jmac72187
corner carver
Running a DR is going to cause massive understeer. I hated it. I am running RT-615's all around now and I absolutely love them.
The DR's feel fine in street corners but once you push your car at all you will see understeer because of the increase of grip in the rear.
RiCe_KiLlEr
Apr 5, 2014 07:00 PM
RiCe_KiLlEr
May 13, 2013 12:15 PM
tbirdscwd
May 29, 2010 03:10 PM
MetalEd
Feb 27, 2010 09:04 AM
phish
Sep 17, 2009 07:27 AM
