500 rwhp but what clutch?
Once my build it done hopefully this summer and will be around the 500 rwhp mark for my weekend warrior/cruiser. I will be running 12-13 psi with a V2SQ aftercooled and CMS 2.5 blower cams. Note: I won't be doing much track use as it is a vert and they require a cage at my nearby track for all verts running 13.49 or less.
What clutch should I go with Spec 2, 2.5 or 3? I am interested in a clutch to handle this power and give me long wear charactistics. Note stage 2.5 clutch is 50 bucks more than Spec 3 kit.
Thanks,
Keith
Thanks,
Keith
yessir! might as well get a stage 3 while ur upgrading then getting a 2 and have it not be able to handle power then have to upgrade again...i have a spec 3 and no complaints...always grabs
03 04 cobra clutch... cheap, will hold the power, and soft as hell depending on how everything else is setup... also can easily be slipped, and is plenty reliable.
By far the best thing to do if you are under 500rwhp..
