rear end options
#42
http://www.jegs.com/webapp/wcs/store...11341_-1_10049
my bad its the lpw stuff, the cover and the tie bar kit above it. i would feel more comfortable with a set of strange 33 spline axles compared to the ones in that kit but that would be your call.
the kit im talking about is the strange one...comes with 33 splines and a spool
it just seems too cheap to include the diff also..but i the listing sounds like it
ok so ive got a diff cover and braces, bearing kit, and then the strange 33 spline/spool package...
think ive got it worked out now...sorry so many noob questions
#44
#46
Axles/Diff
http://www.jegs.com/i/Strange+Engine...00FM/10002/-1#
Girdle
http://www.jegs.com/i/L.P.W./619/101-8.8/10002/-1
http://www.jegs.com/i/L.P.W./619/341-A/10002/-1
Bearing Kit
http://www.americanmuscle.com/rearendrebuild.html
am i missing anything? or do i even need the bearing kit?
Girdle
Bearing Kit
#49
the spool should come with new carrier bearings as alot of them are different spec bearings with a spool i believe. you shouldn't have to do anything with the pinion gear (probably only gonna have to set backlash again by switching some carrier shims). i always like to replace the axle bearings when putting in new axles though since it only takes 2 seconds with a slide hammer. i'd say just get a set of axle bearings and you can always get the carrier bearings at advanced or napa if they don't come in the kit.
#50
cool thanks man...sorry all the noob questions lol
you were a huge help...ill be spending the same amount for 33 spline stuff as i would have been with the 31 spline setup i originally posted
