would the height on 315/30's look to short on my 18's
315/35/17" tire = 25.6"
315/30/18" tire = 25.6" so is actually 1/2" difference between the two in sidewall.
Either of the above sizes will fit fine on an SN95, but "may" have some fender/liner contact if off-set is not correct. This really comes down to personal preference, as the lower sidewall will make your ride a bit harsher. This is something you need to decide
Jazzer
Jazzer
315/30 = 94.5mm
315/35 = 110.25mm
Difference = 15.75mm = 1.575cm so a centimeter and a half to be exact. The wider your tire, the greater the difference between the two will be.
he was asking if the front sidewall would look bigger than the rear sidewall. If the fronts are a 275/35/18 and the rears are a 315/30/18, then there would be a difference of 1.6mm in the sidewalls.
You guys are going on possible sizes of the sidewall of the rear, but that's not what he's asking, he's asking about the difference between the front sidewall and the rear sidewalls, which isn't noticeable.
If your talking about the difference between a 315/30/18 and a 315/35/18, it is certainly noticeable for anyone with decent vision.
either way, comparing the rears to the front, they will have almost exactly the same sidewall height.
He didn't specify so I gave him an answer to the comparison between 30/35 on a 315 and also said if he had 275/35s or smaller up front, they will look about the same as the rear 315/30.
junior04
09-28-2015 10:53 AM
