Idle problem after TB/Plenum install
Old May 30, 2009 | 11:30 AM
01MGGT's Avatar
01MGGT
Default Idle problem after TB/Plenum install
I have noticed every now and then since installing a 75 mm TB and TF plenum My rpms will sit at like 1500 or so after driving for a while and pulling up to a stop light or stop sign or something. However if I put my foot under the gas pedal and pull up i will cause them to go back down but prying to hard makes the car die. I did the IAC restrictor mod but I seriously thing its something more with the throttle linkage thatn that....maybe I install the throttle return spring the wrong way?
Old May 30, 2009 | 11:55 AM
vanquish's Avatar
vanquish
http://paladinmicro.com/PalMFrame00.htm?wks=tba
Old May 30, 2009 | 12:05 PM
01MGGT's Avatar
01MGGT
That was a great read. However it has had a perfect idle for the first part of the install. I will still check it but wouldn't the idle have been bad from the beginning if it were the screw?
Old May 30, 2009 | 01:51 PM
01MGGT's Avatar
01MGGT
The little black plastic piece inside the return spring that connects to the throttle body was loose and jsut sliding back and forth. I clipped it back into place....The part where it is exposed when the spring moves is facing the driver side of the car..is this correct or do I need to flip the spring around? Should I maybe try and get just a new spring or whatever? After clipping it back in lac eI hade no idle problem. It's like it was kaaping the throttle from returning to the normal position and I guess when I put my foot under the pedal and pulled up it forced it back. What purpose does this plastic tube looking thing inside the spring serve?
Old May 30, 2009 | 02:30 PM
vanquish's Avatar
vanquish
I know what you mean that black piece seems to not be secured too well. Here is a pic you can see that piece inside the spring.
Old May 30, 2009 | 02:34 PM
vanquish's Avatar
vanquish
Old May 30, 2009 | 08:29 PM
01MGGT's Avatar
01MGGT
Thats the one
Old Jun 1, 2009 | 09:06 AM
Eagle2000GT's Avatar
Eagle2000GT
It's just a return spring. I took that black piece out a long time ago without any problems. I have no idea what it's purpose was but the car runs great without it.
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
5.0pntydrpr
Aug 27, 2015 10:26 PM
stanngg
Aug 12, 2015 03:43 PM
HIS S-197
Aug 10, 2015 05:47 PM
