A/C Problem?
Old Jun 23, 2009 | 08:06 PM
crazyone's Avatar
crazyone
Default A/C Problem?
Hi,
I'm hoping that by providing some facts on my car,
someone can guide me in the right direction with my 03 mach1 (63,000km)
Stored the car over winter, tried a/c a few weeks ago and noticed it was warm even on Max setting.
I believe it's the clutch that I hear clicking.
Turning on and off every 10-20 seconds.
It worked fine the summer before.
I read If the system is low on refrigerant, the clutch will not engage (safety feature, keeps you from burning up the compressor due to no oil)
I will check this tomorrow:
There are two wires to that switch (the cycling switch)... purple and dark blue/yellow. Purple wire should have +12 when you turn the key on and have the A/C on. If you do, then the dk blue / yellow should also have +12 .... or the switch is bad...
Old Jul 29, 2009 | 09:03 PM
crazyone's Avatar
crazyone
With the recharge and the dye, I was able to determine the condenser is leaking.
Anyone else been through this?
Old Jul 29, 2009 | 09:51 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Sorry I couldnt get to you sooner. But usually a fast cycling compressor is because of low refrigerant. However you were able to figure that out on your own. Leaking A/C systems are unfortunately more common than you'd think. Theres a bunch of causes to leaking components. The condenser isnt a bad job to do yourself, its just having someone evac + recharge the system to spec.
Glad you got it figured out.
vargas
Jun 17, 2017 12:17 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
SteelerNation82
Sep 16, 2015 07:11 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
