only difference
Old Jun 27, 2009 | 04:44 PM
00' GT's Avatar
00' GT
Default only difference
man i hate to ask this question, but, is the only difference between a 2v, 3v, and a 4v motor tha heads? tha blocks are tha same?
Old Jun 27, 2009 | 05:21 PM
mvr's Avatar
mvr
the blocks are not the same.
Old Jun 27, 2009 | 10:32 PM
JJ03MustangGT's Avatar
JJ03MustangGT
a 2v block "can" be made to hold a 4v top end but it takes work.
rwhp is just a rough estimate, not completely accurate!!!
2v is a sohc, 16 valve 281ci v8 230-235rwhp
3v is a sohc, 24 valve 281ci v8 260-265rwhp
4v is a dohc, 32 valve 281ci v8 270-280rwhp
but obviously autos and manuals yeild different gains due to parasitic loss, live axels vs irs yata yata yata. a lot of variables but this kinda gives you an idea
Old Jun 27, 2009 | 10:47 PM
Xemeth's Avatar
Xemeth
Not really. I'm finishing the swap this week, and it wasn't that bad. The 4v heads bolt right to the 2v block no problem. The heads are a bit of a tighter squeeze while in the car, but nothing worse than some of GM's stuff.
The swap is pretty straight forward, actually. You need a lot of little parts, the only big expensive things you need are the heads, cams, and intake. I can make an entire list of everything needed, but unless someone wants to know, I don't think I have the motivation to type it out.
Dokilar
15
Oct 16, 2015 08:13 PM
breaking
Oct 2, 2015 01:27 PM
UrS4
Sep 30, 2015 10:13 AM
mrappe
Sep 26, 2015 10:16 AM
