Which compressor to remove front springs
just put the jack on the control arm and jack it up until the control arm is being held by the jack. Then just start unbolt the strut. The bolts should come out no problem, worst case scenario you have to pound on the tip of it to get it out.
Then just slowly lower the jack.
hmmm.. i am still looking to take out my isolators... thats ALL you have to do?
1) jack up car
2) unbolt sway bar end links
3) jack up control arm
4) unbolt 2 strut bolts
5) relieve pressure from jack on the control arm and take out spring and remove isolators
6) put spring back in
7) jack up control arm and put 2 strut bolts back in
8) lower jack and connect sway bar end links
DONE
thats it?
1) jack up car
DONE
thats it?
I did that for the backs and it worked like a charm.
Lynn
I have some of those spring clamps on there now, so I think I will take em off, and just put one on there now for saftey while I take the bolts out. And as for bangin em out, thats pretty hard to do. There is no room to get a swing on a hammer...
