idleing question
Old Aug 1, 2009 | 12:28 AM
Bman2000's Avatar
Bman2000
Default idleing question
ok so my car has this bad habbit of a rough idle, but not all the time just whenever it feels like it. so my question is what are the posibilitys?
First off, i replaced the iac not to long ago, that helped with some of the problems but i still got left with the shaky butt idle(mind you it can run smooth) the only things i can think of tho is MAF(which i just cleaned, helps but doesnt fix it)fuel filter which is new and didnt change a dam thing TPS? and maybe the crank sensor?
since its kinda a random idle problem i wouldnt think it could be a vaccum leak since i imagine that would be more consistant, i could be wrong tho. Any input would be great, as well as the easiest way to check.
Old Aug 1, 2009 | 01:22 AM
H0SS302's Avatar
H0SS302
Does it do it immediately on start up? If it does not, chances are good that you have a small crack in a vacuum line that only gets exposed as the engine temps rise and the rubber expands a little..causing your issues.
2007StangV6
Jan 28, 2016 06:09 PM
trashxtrash
Sep 20, 2015 10:49 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
96stang3.8
Sep 10, 2015 06:42 AM
