*****Tools Needed*****
Old Aug 10, 2009 | 01:39 AM
brettjr2005's Avatar
brettjr2005
I never go all the way to max, i go like 3/4 of the way to max and change it on time every time.
Old Aug 10, 2009 | 01:42 AM
paintball1's Avatar
paintball1
alright, so it should be more than half between MIN and MAX then. somene told me the MIN line is fine
Old Aug 10, 2009 | 01:50 AM
brettjr2005
The MIN line is fine, but I just fill it up a good amount past to be safe and make sure I don't drop below.
Old Aug 10, 2009 | 01:51 AM
paintball1's Avatar
paintball1
also do u think i am doing any harm to my car? basicaly if i takke off the LM2 and dont put any pipe between that and the over axle pipe, it will basically be Mid Pipe Connected to a little peice of pipe that connects the LM2 which are no longer there to nothing, and then my over axle will just be there. i guese my exhuste will be going out under my car thu.
Old Aug 10, 2009 | 04:16 AM
0hOneGT's Avatar
0hOneGT
so what you're trying to do is take the lm2s off of your car and not replace them with anything? It will sound really horrible. Just throw an off road mid pipe on there if youre looking for your exhaust to be louder and actually still have any tone to it
Old Aug 10, 2009 | 07:01 AM
ChalknCover's Avatar
ChalknCover
Sgt. Killjoy
^ I second that opinon. Get a o/r x or h and it will sound a lot better. I have an h and love it, I actually downgraded from the 1's to the 2's just because it was too damn loud and had no tone whatsoever. Don't just take the 2's off because it wont sound good. And it is a 15mm socket for the slp catback, just adjusted mine over the weekend.
Old Aug 10, 2009 | 10:08 AM
paintball1's Avatar
paintball1
Thanks everyone, but what bout the oil in the MIN and MAX
Old Aug 10, 2009 | 10:57 AM
SVTeeshirt's Avatar
SVTeeshirt
your threads make my head hurt, i really tell myself just to ignore them but i have to open them just to see what you need us to hold your hand with this time.
That and im incredibly bored.
cmon man bolts? it takes all of 2 seconds per try and for the most part you can eyeball what size you need. If its too big go smaller, to small go bigger.
Leave the mufflers on an off road pipe should be plenty loud, as stated no mufflers are gonna sound like ****.
its pretty self explanitory the min and max... the min is the minimum you should have at any time and the max is the max.... i just put 6 in every oil change.
Old Aug 10, 2009 | 11:02 AM
paintball1's Avatar
paintball1
Again do u think it would be best to be in between the MIN and MAX or all the way to MAX. what is the point of a forum if not to 100% make sure im doing everything right.
Old Aug 10, 2009 | 11:05 AM
SVTeeshirt's Avatar
SVTeeshirt
wow you need a reading comprehension class.
I SAID I PUT IN 6 QUARTS BUT AS LONG AS ITS ABOVE THE MINMUM YOU WILL BE FINE.
