What cams would you chose?
#72
back on subject...
Hitech Stage 2 cams are one of the best grinds out built specifically for the stock/mild ported heads. No valve spring change required which for many people is a major +1. Most have reported close to 300hp on the dyno.
CMS Stage 2 is a great grind that works with stock heads but shines when heads are worked on. Valve springs must be changed to prevent ptv contact.
Basically...you can't really go wrong with either cam. Just plan around what future mods you plan on doing.
jwog666
12-27-2021 08:09 PM
junior04
09-28-2015 10:53 AM
