Old 10-08-2015, 01:28 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
o2 sensor questions
Old 08-27-2009, 12:21 PM
justang97
justang97's Avatar
Default o2 sensor questions
My car is running the code bank 1 sensor 2. I have been told many different things about this. I have heard that bank1 means drivers side and i have heard that sensor 2 means passenger side. So I do not know what to believe. Also, is it worth paying the extra 100$ for a ford 02 sensor? Thanks and hopefully yall can clear this up for me.
justang97 is offline
Old 08-27-2009, 12:28 PM
Stevecooper
Stevecooper's Avatar
Bank 1 & 2 and drivers and passengers side. Sensor 1 & 2 is the front and rear 02 sensors
So bank 1 sensor 2 would be the drivers side rear o2 after the cat.
Stevecooper is offline
Old 08-27-2009, 03:54 PM
Radii
Radii's Avatar
Generally, Ford and Motorcraft parts are always more expensive and don't perform any better or worse than aftermarket parts. I would save the money and get some aftermarket O2 sensors.
Radii is offline
Old 08-27-2009, 04:11 PM
jwog666
jwog666's Avatar
bank 1 is the bank with the number 1 cylinder and sensor 2 is the sensor after the converter. so your code is for the right bank and the sensor furthest away from the engine. the left and right of a car are viewed as if you are sitting in the car, not as if you are standing in front of it.
and what code is it running exactly? some of the o2 sensor codes can be caused by wiring and not the sensor itself.
jwog666 is offline
Old 08-27-2009, 04:24 PM
justang97
justang97's Avatar
see both of yall told me different things. steve said its on the left and jwog said its on the right..im even more confused...the actual code is po141 and po136 are the codes that ran...please clear this up
Old 08-27-2009, 04:55 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Bank 1 is the passenger's side, that leaves Bank 2 being the drivers side...
Here's a diagram, sensor 11 = bank 1, sensor 1, 12 = bank 1, sensor 2, etc...
Re Ford vs. Bosch, get the Bosch--it's just as good as the Ford unit an will save some money. There are those who will disagree, that's fine--if you wish to believe them then get the Motorcraft part...
cliffyk is offline
Old 08-27-2009, 05:13 PM
LS WHAT
LS WHAT's Avatar
ditto
I get mine from autozone, no problems, and if it don't fix it you can take it back.
LS WHAT is offline
Old 08-27-2009, 08:20 PM
DreamerGT
DreamerGT's Avatar
Yeah Bosch are the ones that make motorcrafts o2's
DreamerGT is offline
Old 08-27-2009, 10:11 PM
justang97
justang97's Avatar
so there are actually 4 o2 sensors? and is there a difference in the 11 and 12 ones? so would should i specifically ask for at the parts store, because they probably will not know what the hell i am talking about
Old 08-28-2009, 08:04 AM
devongarver
devongarver's Avatar
If i remember right, they had two different models when i replaced all four of my o2 sensore when i did my full exhaust,...the two fronts are one model, and the two rears are another. Im not sure if one set is heated and one isnt or what, i cant remember. Just tell them at the counter, they have a computer that telles their dumbasses what to get you.
BUY ME!
devongarver is offline
Quick Reply: o2 sensor questions
