idle problem
Old Sep 15, 2009 | 05:18 PM
nos-nick's Avatar
nos-nick
Default idle problem
whats happin everyone got a problem my 00 gt has an idle problem that has recently reared it head the car will not idle at start up untill you ream the h_ll out of it, but how it will try to go dead when shifting gears anyone ever had this happin I don't know if its the tps or something else please help.
Old Sep 15, 2009 | 05:19 PM
99BlackPonyGT's Avatar
99BlackPonyGT
aka 'Negative Nancy'
IAC...clean or replace
Old Sep 15, 2009 | 05:28 PM
disposablehero27's Avatar
disposablehero27
had mine do that, every time i slow down it'd shut off, turned out to be the aftermarket throttle body needed to be cleaned and adj just a tiny bit. Found that out after cleaning and then replacing the IAC, no change, then cleaned the entire air intake system, with the TB, it was sticking closed when i slowed down, so bumped that screw up a little bit.. fixed it. Its a little screw that is located on the side of the TB that keeps that arm in place to adj idle. bumped the idle up just a nut hair.. fixed it.
Old Sep 15, 2009 | 07:50 PM
99BlackPonyGT
try the IAC before you start adjusting your idle..
Old Sep 16, 2009 | 02:52 PM
nos-nick's Avatar
nos-nick
thanks for replying IAC idle air control i presume? where is it located. can i rule out the tps i've cleaned the t/b not long ago
Old Sep 16, 2009 | 03:02 PM
99BlackPonyGT
http://www.moddedmustangs.com/cleaning-your-iac.html
and heres a better pic of the valve on a 4.6
http://mineralgray02k.com/writeups/t...abWrite-up.jpg
right in the middle of the pic, circled
Old Sep 17, 2009 | 03:25 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
The throttle stop screw is NOT an idle adjustment, if you mess with it you'll need to reset it via this procedure.
The PCM will do all it can to maintain the programmed idle speed, by using the IAC to control intake air flow. However, it expects a certain amount of air to be "bleeding" past the throttle plate¹--the adjustment link above explains how to set this up so that the IAC will be operating in the lower 20% of it's range at idle.
¹ - The throttle plate would stick closed due to combined forces of stiction, binding, and manifold vaccum if not held slightly open by the stop screw.
Old Sep 17, 2009 | 11:26 AM
nos-nick's Avatar
nos-nick
thank alot , i'm going down and clean it thanks for the pics. but there's a new sym. this morning as it was running i disconnected the bat. to check the alt. turned the lights,defrost,and radio on, and a grinding noise came from the clutch/bellhousing have any ideas. i'm puzzled??????
Old Sep 17, 2009 | 02:13 PM
dubarado's Avatar
dubarado
check the tubing leading into the IAC as well... I had idle issues as well, and replaced the IAC and the TB and nothing... went to go pull the tube off from the intake to the IAC and there was a piece of cloth stuck in it!
Old Sep 20, 2009 | 11:04 PM
nos-nick's Avatar
nos-nick
thanks alot guys i cleaned the iac and that fixed the problem owe you guys thanks again.
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
