New idea,
machine work on the block would be hot tank cleaning, new freeze plugs, main bearing line boring, cylinder boring, decking the block.
then theres the head work, checking for warpage and machining, new 3 angle valve job ( or 5 angle if you want to spend the cash) new valve guides.
then theres the rotating assembely, line boring the connecting rods, weight matching the rods, sizing the pistons to the cylinders, checking the balance on the crank, polishing the crank.
i had a 3.8 priced at my local machine shop for all of this and them assembling the short block and it was 1400.00 just for labor.
theres more places to look but heres some
http://www.dssracing.com/SearchResults.asp?Cat=60
http://www.coasthigh.com/Ford-4-6L-M...cks-s/1251.htm
http://www.modularmustangracing.com/
its my opinion that if you want to build an engine the right way go ahead and do it but i tell you first hand theres alot of measurements that have to be dead on.
now if you want to "build" your own engine by just putting on some heads, setting the timing and putting on the finishing touches and dropping it in that would be a good learining experince too, just dont get in over your head and loose a bunch of cash because something wasnt right and your engine went boom.
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
and my dad knows a guy who owns a machine shop
