loss of power and ticking when reved high what is it?
Old 10-20-2009, 06:11 PM
JC316
JC316's Avatar
Hmm, I don't think it's a valve spring or a lash adjuster. The adjuster wouldn't cause power loss, but it would knock. These springs don't usually just weaken, they just flat out break. I would almost say that it's a coil that is cracked and arcing against the cylinder wall. That would cause a ticking noise and cause a loss of power.
JC316 is offline
Old 10-20-2009, 06:32 PM
Repzard
Repzard's Avatar
/\ I agree with this member.
I had a problem kinda like the thread starter and I replace the boot on my cop's (had a few cracked ones) and while I was replacing them I found a cop that was moving alittle to easy side to side on the mounting screw which was causing some of the issue.
I have to agree its cop related and arking from dried cracked boots.
possibility
Hesitation - Because its arking
Ticking noise - The ark itself
Repzard is offline
Old 10-20-2009, 06:34 PM
Repzard
Repzard's Avatar
A test would be to start the car in the dark and see if you see any arking in spark plug holes.
Good Luck
Repzard is offline
Old 10-20-2009, 06:59 PM
tempoffroad
tempoffroad's Avatar
if it is a cop would that only happen at higher revs and then last for a few minutes then go back to normal? i will check everthing. would it be the cop itself or the boot? how do you test the cop?
ok i just came in from checking in the dark i moved every cop in out up down side to side and i didnt see or hear anything. they all looked good to me. i just changed plugs so maybe that was it?
Thanks guys.
tempoffroad is offline
Old 10-20-2009, 07:28 PM
teej281
4.6L Section Moderator
teej281's Avatar
My old motor did this and i think it was cop related. never got it checked out but my something was wrong with my cop's.
teej281 is offline
Old 10-20-2009, 08:14 PM
Nichoms
Nichoms's Avatar
Ya I would think it would have to be a spring, a lifter (lash adjuster), or the tiniest possibility a flattened lobe on your cam, which I would think all of these would not be intermittent.
Are the 4.6 lash adjusters hydraulic? I'm not very experienced with the mod engines
Nichoms is offline
Old 10-20-2009, 08:57 PM
JC316
JC316's Avatar
Yes, the lash adjusters are hydraulic. I still say that it's ignition related. I had the adjusters knocking on my old 2V and it didn't loose power in the slightest.
JC316 is offline
Old 10-20-2009, 09:21 PM
tempoffroad
maybe after christmas i will order some weapon x cop and see what they do. i think it is around 450 a set.
Nick Oliver
10-17-2018 04:22 AM
jessicarabbit
09-25-2015 12:41 PM
2015Ecoboost
09-17-2015 01:48 PM
Pyrate Dave
09-10-2015 07:30 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: loss of power and ticking when reved high what is it?
