Installed steeda pulleys
As far as quality UDP's go, I don't think there is a better quality than the steeda's but no matter who makes it, at some point, the smaller mass and diameter just doesn't have enough material to control all/most of the TV.
(A fully built & perfectly balanced engine would be able to combat this more effectively if it were forced to have a smaller HB but it doesn't guarantee anything.)
The 4.6 is easily a 200k mile engine but the less control the HB has on it the sooner it's going to give out. So instead of having 200k miles of fun, you could have only 120k +/- what ever the car gods see fit.
Think of a smaller HB as a woodpecker.... It just picks away at a tree little by little and eventually it burro's it hole. The smaller HB pecks away allowing more TV and eventually it's going to give out.
Think of a figure skater doing his/her spin, the closer the arms are drawn in, the more pressure is placed on the center of mass (Angular momentum) and more muscular tension needs to be held in order to keep control.
Sep 8, 2015 11:50 AM
Sep 2, 2015 08:40 PM
