what part of you have no Hydraulic clutch is not getting through your head. There is no fluid of any kind in your clutch system
Your clutch is probably stiff because it is an aftermarket clutch.
If you want a soft clutch get a honda , unless your clutch is slipping or you hear a chirping noise you should be golden. No need to change your clutch oil or the batteries in your fluxcapasetter.
