Which tubular k with stock A arms
I would suggest checking these out.
http://www.ajeracing.com/mustang.php
You can buy the spring perches and run stock A arms. And the Kmember comes with motor mounts (although not what you're thinking) and rack/A-arm mounting hardware.
Something i am going to say is that with the lighter front end, your car will sit uneven with regular springs in the front because the front end will get lighter, but your spring rate isnt going down, nor is it adjustable. I was thinking about doing the same thing. But then i thought why not just get a upr tubular k member kit and spend $700 with coilovers and everything??? Its like $300 more than what youre looking at spending on just the k member, its the lightest k member out there, and you will have adjustability with it. Just something to think about.
lizzy just saved me $300...
IS THERE ANYTHING THIS MAN CANT DO LADIES AND GENTLEMEN??!!
Please, a round of applause =)
teej: thanks for the suggestion tho, im sure future thread searches will appreciate the info, i just need to save as much as possible- only the necessities!
I honestly think it will look funny and you arent dropping much weight with that K member it looks like which is what i thought the goal was. Thats why i thought to suggest the lightest k member on the market.
Even with stock springs it looks fine and the fitment of the PA unit is far superior to UPR's and I saved well over 30lbs
