The man in brown IS FTW
Old 11-24-2009, 05:01 PM
  #21
amoosenamedhank
amoosenamedhank's Avatar
Originally Posted by Xemeth
That's cool as long as you have the right tool to do it. The compressor I was using was for pushrod motors, so that didn't help. And I had to do 32, so I said **** it.
Just make sure to change the valve seals while you're there. For what they cost it doesn't make any sense not to.
Yeah that will definitely wreck your day.. I started with one of those, and said F*** it. And just spent the money on the right one.
amoosenamedhank is offline
Old 11-24-2009, 06:16 PM
  #22
H0SS302
H0SS302's Avatar
Wondering if I should pull the trigger on some new trick flow valve covers or not.. worth it?hmm....
H0SS302 is offline
Old 11-24-2009, 06:23 PM
  #23
98redstang
98redstang's Avatar
Originally Posted by amoosenamedhank
If you have the air fitting for the spark plug hole and the right compressor.... it's no biggy at all.
I saw and used this trick when i had to change my valve seals. You used string and put it in there when the piston is tdc and it hlds the valves upworked like a chram.
98redstang is offline
flash_xx
10-16-2015 07:23 AM
Explosive
10-02-2015 07:45 AM
mungodrums
09-29-2015 09:18 PM
LivingInThePast
09-16-2015 12:20 PM
showoffzx2
4 Cylinder NA and Turbo
09-14-2015 08:40 PM
Quick Reply: The man in brown IS FTW
