A/F Ratio
Old Dec 22, 2009 | 12:51 AM
1999mustang2000's Avatar
1999mustang2000
Default A/F Ratio
How can i find out what mine is. With a stock fuel at WOT it'll act like you didnt even put the pedal to the floor but if i take fuel out with the tuner itll run good so i wanna see what my a/f is because i think its running so rich that it cant burn off the gas that enters the engine and it sorta floods out
Old Dec 22, 2009 | 01:00 AM
S197winstang's Avatar
S197winstang
get a dyno run
Old Dec 22, 2009 | 01:07 AM
1999mustang2000
I plan to but i have to wait for a month or two. Im just trying to get it running pretty good for the time being. It has a big *** c&l MAF on it right now and im not sure if the previous owner had it tuned for it and i dont have a stocker to through on it.
Does anyone know if the v6 maf is the same size as the gts?
Old Dec 22, 2009 | 03:37 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
Buy a wide band O2 system--you shouldn't be messing with fuel settings without one...
The V6 MAF is not the same as the OEM GT unit. It uses the same sensor however the housing is 70mm ID--the GT housing is 80mm, the transfer functions are entirely different...
Old Dec 22, 2009 | 07:29 AM
teej281's Avatar
teej281
4.6L Section Moderator
Just get a lightning maf and put that in. It will be easier for you to do the transfer on your tuner, if you have one, because the lightning maf is such a popular upgrade that most tuners already have the capability to switch between the stock maf and the lightning one in it.
Old Dec 22, 2009 | 09:28 AM
01MGGT's Avatar
01MGGT
Get an innovate wideband on ebay for less than 200 bucks...Tehn you will always know your A/F Ratio
Old Dec 22, 2009 | 09:46 AM
mikeob1's Avatar
mikeob1
Default Innovate Motorsports
Get one of their AF meters
Jb145700
Aug 21, 2022 06:37 AM
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
articman
Jun 21, 2018 11:45 PM
uberstang1
Sep 20, 2015 06:42 PM
Sep 3, 2015 07:14 PM
