Ok, suspension help.
I was thinking AM. I want the sfc's indefinitely but I would really like springs. I was thinking H&R's but I do not want to have to get CC's and aftermarket shocks and struts atthis point. That's why I am thinking of running the Pro Kit. What does everyone think?
The MM's come with very detailed instuctions (probably the best of any aftermarket brand I've seen), and if you lose them then it's up on their website. Speaking of MM, look into some lower control arms as well. And the subframe connectors can be painted if you want to save the money by getting the bare ones (what I did, now just need to get them welded on, for almost 2 years now....).
You will notice a different once they are installed!
GOOD LUCK!
Last edited by TRUEBLUE3934; 01-05-2010 at 11:23 AM. Reason: had to erase text types twice
Prokits SUCK A$$!!! i hate mine!!! they dont sit level and the rear sags. If the front was as low as the rear, i'd be happy. But no, the stance sucks. Go h&r's and get the cc plates. Shocks and struts arent a must but they are nice to have. They will give you better ride quality and should be in the plans for down the road because the lower suspension will wear them out quicker but arent necessary right now. Go with H&R's or at least sportlines.
Matt's 95 Stang
10-05-2015 07:16 AM
