Mach 1 brakes
Even though you have the 13" rotors, you need the GT SS lines?
You didn't need to buy any banjo bolts or anything like that?
EDIT: how much did it all run you?
it seems that if the calipers are only 189, lets say blank rotors are $120 and SS lines are $70, its cheaper than what the kit used to cost from buyford racing. That only comes out to around $380ish
I used my stock banjo bolt (it was the right thread) and new copper crush washers that comes with the lines.
With autozone rotors @ $70 ea. = $400
You just need some fluid and hose to bleed.
Soak the hell out of the caliper bolts, I busted 2 craftsman 15mm 6 pt. 3/8 drive sockets. I finally got it off with a 15 mm 1/2 drive socket and used a floor jack to turn the bugger. lol
haha no problem MG
Thanks p51
And jsut to simplify...if people want to do this, they need to order:
2 13" rotors
2 of those calipers in the link above
and maybe 2 of those SS lines for a GT and not for a cobra (idk if there is a difference). But the SS lines aren't mandatory correct?
Thanks p51
2 13" rotors
haha no problem MG
Thanks p51
2 13" rotors
Thanks p51
2 13" rotors
Corrrect, ss lines aren't mandatory, but figured I might as well since I was there. I didn't do it myself, so I can't say how easy/hard it was. No, you don't need banjo bolts (with the cobra ones you do though).
And yes, putting together the kit myself saved $$ over the kit they had before, so it really worked out to my advantage.
Eventually I'm planning on doing something with rims. I want deep dish rears, but the supercharger is at the top of my list right now (debt free as of a month ago, so I'm really ramping up the savings for the stang)
Matt's 95 Stang
10-05-2015 07:16 AM
breaking
10-02-2015 01:27 PM
09-25-2015 06:42 PM
