Best Exhaust Combo?
ok so, does anyone know if Kooks would be the way to go to make installing headers easier.
and I believe the inside of my magnaflow mufflers as a V shape piece of metal on the inside in front of the inlet hole and is empty, whatre yall saying it has?
Its a chambered muffler so thats what its supposed to be like. Anyways, kooks makes some real quality headers man. They are probably what would go on any of my cars if they ever get headers. I dont know if they will install any easier but they will probably fit better cus they are quality.
I like my setup.... IMO but others sound and work great too, LTs are a pain to put in but worth it, and more easy if your swapping your k-member too. The BBKs have the slight dent to clear the steering shaft but I think its MMR makes a new steering shaft thats made to clear headers.
http://videos.streetfire.net/video/C...ing_703528.htm
http://videos.streetfire.net/video/2...-GT_648430.htm
http://videos.streetfire.net/video/0...out_727271.htm
There are two sounds I love from modulars, Flowmaster H pipe and Borla X pipe (Neither having cats). You give up a little with either one More drone with the flows and Higher pitch in the upper range for the Borla. Either would sound great.
A lot of people will also say you can't tell the difference between stainless and aluminized steel but I think you can and stainless holds down the rasp a bit more. Your tail pipes also have a lot to do with the sound.
^^ the only exhaust set ups that should be allowed for our cars ^^
