Cold air intake loud @ idle
Old 04-16-2010, 03:47 PM
  #31
cliffyk
TECH SAVANT
cliffyk's Avatar
There is some serious air leak in the filter to MAF coupling, or the MAF body may be damaged, or perhaps something after the MAF?
I don't see the IAT sensor, is it under the pipe after the MAF--or is there perhaps just a hole where the IAT sensor is supposed to go?
Is there a hole in the filter, or something blocking the filter's output?
cliffyk is offline
Old 04-26-2010, 08:49 PM
  #32
01stangman01
01stangman01's Avatar
i had a problem about a month ago with the idle hanging and not being responsive and it was a plenum gasket leak which caused it. I thought at first vaccuum leak or Idle control valve being dirty but it was the gasket from getting on it too much. BUt that sounds terrible
01stangman01 is offline
Old 04-26-2010, 09:11 PM
  #33
Pohatu18
Pohatu18's Avatar
Ive got a slight hissing from my brass fittings on the intake manifold comming out causing a gap between my upper plenum and manifold(replacing the manifold tommorow). This sounds more from the intake where the filter connects to the MAF.
Pohatu18 is offline
Granatelli Sales
01-20-2020 12:34 AM
Webster454
09-07-2015 04:59 AM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: Cold air intake loud @ idle
