bigger injectors mean bigger maf?
You might need to upgrade your MAF depending on how much power you are putting down. I'm assuming there is a good reason for the new injectors, most likely a blower. In that case, you will need a bigger MAF around 400rwhp.
What mods do you have that make you believe need higher capacity injectors?
As to the stock MAF on your '04, it's good to over 2700 lb/h which at 12.5:1 AFR = 216 lb/h of fuel. which running n/a = over 432 flywheel HP.
If you want to spend money, open up the exhaust and then buy a tuner...
hey i have heads,cams,rods,bored .30 over,headers,tb,exhaust cam...et cfull bolt ons plus heads and cam and its tuned on sct now and im running 90shot of nitrous im upgrading to a 125shot and buying 42lb injectors and a 90mm mas air. will i need the mass air? when parts get here i am having SGS tune my car
BTW--1200 kg/h = 2640 lb/h, at 12:1 AFR you'd mix 220 lb/h of fuel with that air, running n/a and assuming BSFC of 0.5 lb/HP that's 440 fwHP...
jwog666
Dec 27, 2021 08:09 PM
