meth injection hp increase numbers
Old 02-24-2010, 12:32 PM
tbirdscwd
tbirdscwd's Avatar
Very true teej. People tend to mix up the reasons why fuel curves are so much richer under wide open throttle conditions. Take for example a mustang running 10psi on a centifugal blower. A "safe" tune will have the a/f ratio right in the mid 11/1 range. This is not because it makes the most power there. Actuall most boosted apps will make most power in the low to mid 12/1 range. Unfortunately, the extra fuel is needed to cool keep temperatures down far enough to prevent detonation. This is where some hp can be gained back by leaning out the fuel curve and keeping the intake charge cool by some other means, in this case, meth injection. The same thing goes for timing. Most tunes aren't running the tha max timing for power output either for the same reasons. The more timing you run, the more likely you will be to run into detonation. A meth kit would allow more timing than pump gas will allow you to run by itself. On the timing side, it has similar effect of running much higher octane fuel.
tbirdscwd is offline
Old 02-24-2010, 12:37 PM
teej281
4.6L Section Moderator
teej281's Avatar
Its like running 116 octane race gas from my understanding. I might look into a meth kit for n/a for the time being and then once i FI it, just adapt the kit to run with the FI. I dont think it could hurt really.
teej281 is offline
Old 02-24-2010, 03:30 PM
GT35thconvertable
GT35thconvertable's Avatar
wow 11 replies.. i havent been on here alot lately and well im running a whole different set up now than the procharger.. i have a 01 4v swap, vortech t trim 16 lbs boost air/water intercooler. made 549 hp 477 tq.The main reason I bought the kit is my intake temps were really high. still would love to see some numbers
GT35thconvertable is offline
Old 02-25-2010, 07:05 PM
Snakebite64
Snakebite64's Avatar
Originally Posted by teej281
OP has a procharger running 17lbs of boost and a 50 shot of nitrous...why you talking about N/A???
Because I guess. I do not have a life is the other reason. Now knowing he is blown I guess he will see increases that will blast him to the moon
Snakebite64 is offline
Old 02-25-2010, 07:09 PM
Snakebite64
Originally Posted by demighost
LOL reading pwns them...
Great I'm new to the site and you have already made me cry, thanks
Old 08-12-2010, 04:46 PM
GT35thconvertable
still looking for those numbers..bought a kit and waiting til my engine is done to try it out
jwog666
12-27-2021 08:09 PM
mungodrums
Suspension
05-16-2019 09:36 AM
rksnow1
09-14-2015 08:46 PM
TfcCDR
09-14-2015 12:08 PM
09-08-2015 11:50 AM
Quick Reply: meth injection hp increase numbers
