timing chain question
Old Mar 13, 2010 | 06:41 PM
Bman2000's Avatar
Bman2000
Default timing chain question
tore the front of the motor apart now, and i stopped because i noticed that one side of the motor the chain is nice and tight, the other side tho has slack in it? Im assuming that the slack means the chain is stretched or a guide is worn or somthing, but id figure id ask. Is that normal? and if it isnt whats the best way to go about tracking down the problem, because i really dont want to buy a timing set at 300plus bucks...not really in the budget and everything apears to be in really good shape other than the slack. Any ideas?
Old Mar 13, 2010 | 06:43 PM
a_penquin's Avatar
a_penquin
check the tensioner and guides for excessive wear, otherwise its a chain.
Old Mar 13, 2010 | 06:45 PM
Bman2000's Avatar
Bman2000
im assuming the tensioner itself isnt likely the problem then?
Old Mar 13, 2010 | 06:48 PM
a_penquin's Avatar
a_penquin
the tensioner itself could have froze up, its possible.
Moonshine's Avatar
Moonshine
By one side tight and one side slack you mean on bank A and bank B? Or one side of the chain is tight and (on the same chain) the other side is slack. In this case...that's completely normal.
Old Mar 13, 2010 | 07:00 PM
Bman2000's Avatar
Bman2000
what i mean is the drivers side chain is tight, on both sides. and the passenger side chain is loose on one side, as in moveable slack. I was thinking that at first that one side of the same chain would be loose, but when i checked the other side it was nice and snug all the way around.
Old Mar 13, 2010 | 07:49 PM
Mustang_NTriangle's Avatar
Mustang_NTriangle
This is totally normal.
Old Mar 13, 2010 | 07:51 PM
Bman2000's Avatar
Bman2000
care to explain why one chain is totally different than the other? not to mention there isnt suposed to be too much slack to begin with, that im sure of. Im just surprised its on one timing chaing and not the other.
CarrieS
Sep 1, 2015 01:00 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
stormesixx
Aug 25, 2015 09:11 AM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
ding56
Aug 14, 2015 02:40 AM
