Cam question
Old Apr 5, 2010 | 06:26 PM
tbirdscwd's Avatar
tbirdscwd
If you are planning on a blower in the future, I totally agree with everyone above. Blower cams will be fine on an N/A setup no matter how long you are running. They won't add as much power (while N/A) as an N/A specific cam, but you will be much better off once you go F/I.
Old Apr 5, 2010 | 07:32 PM
Mustang_NTriangle's Avatar
Mustang_NTriangle
also just so you know blower cams don't sound nearly as choppy as na cams just so you know.
Old Apr 5, 2010 | 08:17 PM
nd22121's Avatar
nd22121
Hmmmm. Did not k ow that. Thanks.
And I am going to check out the modualr head shop as well. I'm thinking I might try blower first. Been reading around and trying to find I stall prices for cams. Seems like it may be expensive.
Old Apr 5, 2010 | 08:35 PM
DarkShadow04's Avatar
DarkShadow04
my local head shop quoted me at 300 with tune
Old Apr 5, 2010 | 09:09 PM
tbirdscwd's Avatar
tbirdscwd
Yeah, most blower cams won't have as aggressive of an idle. They are very noticeable though, especially with an aftermarket mid-pipe and catback. Most blower cams sound about what a stage 1 N/A cam sounds like.
All that being said, you should be choosing a cam based on power and how well it fits your setup, not what the idle sounds like.
Install prices tend to vary a lot from shop to shop, and whether or not you are having the valve springs replaced.
Old Apr 6, 2010 | 10:47 AM
nd22121's Avatar
nd22121
Nah, I am not basing how they sound as to which I'm gonna buy, just didn't realize they were different.
Still trying to decide if I want to get blower or na cams. I mean I really plan on s/c but if for some reason something would come up where I couldn't afford it at the time(cause I would like to do this by the end of thesummer)I don't want s/c cams in my car then.
But I would really like to do cams first before the blower beause I am impatient and they are the cheaper of the two right now.
Old Apr 6, 2010 | 12:19 PM
tbirdscwd's Avatar
tbirdscwd
Just remember if you run blower cams n/a you might leave 10-15 hp on the table vs a lot more if you run na cams with a blower.
Old Apr 11, 2010 | 04:37 PM
nd22121's Avatar
nd22121
So are these the blower cams from mod head shop you are talking about.
http://cgi.ebay.com/ebaymotors/4-6-5...item19b61c576b
and my year car is PI right? Because I also see ones for NPI as well. Btw these were from their eBay store.
Also, I didn't think about this but will the cams screw with my emissions or is that one of the reasons a tune is required after a cam install.
Old Apr 11, 2010 | 06:58 PM
mrtstang's Avatar
mrtstang
Yes, cams can screw with emissions. There are some possible ways around that with tuning, running stock exhaust, injectors, etc...but there are no guarantees. It depends on the testing as well.
Your car does have the PI heads assuming it has the stock motor.
Those cams are good for a mild blower setup.
Old Apr 11, 2010 | 07:25 PM
tbirdscwd's Avatar
tbirdscwd
Call Tim over at MPH and get a set of his custom blower grinds. They will be good for over 280rwhp with full bolt ons N/A. I have already passed CA emissions with them with a mildly modified stock tune, probably would have passed with a completely stock tune, but I didn't want to chance it. As for how well they perform once FI, there is very few cams that even come close to them.
