Cam question
Old Apr 2, 2010 | 08:21 PM
nd22121's Avatar
nd22121
Default Cam question
I hate to start a new thread just for this but I'm having trouble finding an answer.
I was looking at the stage 1 cams that AM sells and I want to get them. But then I see they sell cams that cost a lot more for FI applications.
If I were to get the stage 1's then get a blower in the future would I be able to keep those camms in or would I have to get a new one.
Old Apr 2, 2010 | 08:38 PM
mrtstang's Avatar
mrtstang
What cams are they? Most stage 1 n/a cams (and some stage 2's) will work with a blower as long as you run lower boost.
Old Apr 2, 2010 | 08:42 PM
nd22121's Avatar
nd22121
Like these stage 1 cams.
http://www.americanmuscle.com/mustan...s-xe262ah.html
I also looked at the stage 2 but I remember reading that an n/a setup shouldn't get them, which is what I am at this time
Old Apr 2, 2010 | 08:51 PM
mrtstang's Avatar
mrtstang
Yeah, they would work with mild boost. They just won't be the best choice. You could also buy a blower speced cam now if you think it's in your future. It would probably only cost you 5-10 hp n/a.
PTV clearance will be very tight with those stage 2's. That's the one main reason i'd stay away from them.
BTW, if you think you will most likely stay n/a, there are better choices IMO.
Old Apr 2, 2010 | 09:01 PM
nd22121's Avatar
nd22121
Well I want to do a blower. But I really like the sound of cams. Are the blower spaced cams the ones that are like $1500?
Old Apr 2, 2010 | 11:36 PM
mrtstang's Avatar
mrtstang
Blower and n/a cams cost the same. Average cost is around $600.
Old Apr 4, 2010 | 08:32 AM
Mustang_NTriangle's Avatar
Mustang_NTriangle
OP if you are planning on doing FI in the future then I recommend you buy blower cams even though you are na today. I would go for a stage II cam like CMS II blower cam.
Old Apr 4, 2010 | 08:16 PM
nd22121's Avatar
nd22121
And that would be okay to run na for almost a year, maybe less??
With blower cams
Old Apr 5, 2010 | 05:37 PM
mrtstang's Avatar
mrtstang
It would be fine, as long as there are no clearance issues to begin with. There are plenty of blower type cams that you could run in the meantime, without issues. Check out Modular Head Shop. They have a ton of different grinds.
Old Apr 5, 2010 | 05:57 PM
lizzyfan's Avatar
lizzyfan
Underboss
What he said^
