Nitrous....help me
Old Apr 18, 2010 | 09:18 PM
WannaBeGearHead's Avatar
WannaBeGearHead
Go Texas!!!
Originally Posted by mustangGT7822
oh and its got an sct chip from american muscle thats tuned for a 100 shot...could that be the problem...do i have more retardation than i need?
After reading that, you need to adjust your tune. The tune for a 100 shot is not good.
Old Apr 18, 2010 | 10:59 PM
thunderhorse's Avatar
thunderhorse
yeah +1
a nitrous tune from a dyno is irreplaceable as compared to a handheld tune. also, if you can find 91 or 93 octane gas close to home, it's worth it.
Old Apr 18, 2010 | 11:03 PM
GTRACER88's Avatar
GTRACER88
Just take your "tune" off. There is no reason for any form of tune for a 100 shot or less!! Period. End of story.
Old Apr 19, 2010 | 12:07 AM
mustangGT7822's Avatar
mustangGT7822
Originally Posted by 01GT4.6
wow you are being way too vague. It's going to be impossible to diagnose like this, I'd suggest bringing it to a competent tuner.
Im being vague because i have no idea what this is...its like the car is back firing...the nitrous works and i can feel the small push but the car will randomly backfire or pop and my tune came from American Muscle. We have a place here in Amarillo that can tune my chip..Maybe i should just look into that.
Old Apr 19, 2010 | 12:09 AM
mustangGT7822
So your saying that I should just run the car with the stock computer tune??
Old Apr 19, 2010 | 12:11 AM
mustangGT7822
The tune itself is not good or the fact that im trying to use a 100 shot tune with a 75 shot is not good??
Old Apr 19, 2010 | 01:14 AM
GTRACER88's Avatar
GTRACER88
Yes. Final Answer.
Old Apr 19, 2010 | 01:17 AM
GTRACER88's Avatar
GTRACER88
Plus, are you running one step colder plugs?
Old Apr 19, 2010 | 10:27 AM
WannaBeGearHead
Go Texas!!!
With only a 75 shot you don't need to adjust your timing at all. I'm guessing in your 100 shot tune they have pulled 2-4* of timing (if possible with those kind of tunes).
Like I said, this is what you need to do: Run 91 or 93 octane, preferrably 93 octane, make sure the tune you have hasn't changed the factory global spark, make sure you are running stock heat range plugs and make sure no timing has been adjusted. Running your car on the factory tune would be better than what you are running now. If you want AM.com to write you another tune, make sure they don't adjust the spark and timing.
If I was you I would not run your nitrous until you get this worked out. With only a 75 shot I really don't see the need to take it in to get it tuned. If you do take it to a shop to get tuned run a bigger shot.
Old Apr 19, 2010 | 10:54 AM
dimebag's Avatar
dimebag
I ran 100 on a stock tune w 93 in it for a long time.....sounds like ur rich as ****
